Old 05-31-2007, 02:28 AM   #1 (permalink)
essex is on a distinguished road
Default Help finding shortcuts to programs
Hey guys, I'm working on a homescreen and I was having trouble finding a few shortcuts directly to programs... Namely the .lnk files to the text messages and camera... I know they're both accessed from within other places (like text messages are accessed from the messaging screen and camera accessed from the pictures/videos screen, but I was wondering if it could still be done.)
Thanks!
essex is offline
Old 05-31-2007, 06:58 AM   #2 (permalink)
Qryan is on a distinguished road
For Messaging:
\windows\\Start Menu\Messaging.lnk
For Camera
\windows\\Start Menu\Pictures & Videos.lnk
That wont open the camera directly....im not sure where the camera app is, but maybe someone else knows. But, that is the extension to use for your shortcuts. fyi, it is also the extension to use for the icon.
hope that helps you somewhat.
Thanks,
Ryan
Qryan is offline
Old 06-01-2007, 01:47 AM   #3 (permalink)
Haha.
I'm already utilising those two... I meant I need the ones for the exact features (if they exist).
And I already have custom icons.
Thanks though...
Anyone?
essex is offline
Old 06-01-2007, 11:47 AM   #4 (permalink)
Pony99CA's Avatar
Default Special Shortcuts
To get the camera, try using pimg.exe -camerakey in the shortcut file. Specifically, use this text:
29#\Windows\pimg.exe -camerakey
That works for me, but your shortcut won't have an icon (which is OK if you're only going to use it on the Home screen with an image).
I don't know how to get to the Text Messages account directly, but try finding a Home screen that does it and use that shortcut. There's probably some command line option for the tmail.exe program.
Steve
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
