Old 11-14-2008, 08:09 PM   #31 (permalink)
Geekster's Avatar
HAHAHAHAHAHAHAHA
Hey, wait a minute........oh my. That bike & the muscle shirt does make me look fat!!!!
Simple solutions to your problem are: A Master Reset or you may have to edit the binary information by encrypting the decimals of the dynamic part of the triothonic file..duh who doesnt know that? .... Make sure you dont overclock your multilomoter when you editing the binary files b/c it might reconfigure your harddrive and your q might blowup.
See? Simple solutions.
http://www.frappr.com/?a=constellati...d=137440517530
Geekster is offline
Old 11-14-2008, 11:30 PM   #32 (permalink)
TreeFrog's Avatar
Originally Posted by fatality View Post
yeah, i've tried a few other themes. zip files generally don't work. the cab. files do work though, even if i follow the steps made by eko i just cant make zipped files work. i do have facade installed..
OK....here go!
Worked great for me...I have Facade also! I pm'd/emailed Tenchistyle to make sure it was ok to cab this and will pull it if for some reason he/she wants it pulled. I didn't change any names on the files. I did change the image file location as I couldn't figure out how to add the folder "eb" to the cab!
I also pm'd eko...as I used a cab of hers for a base (as i have no clue how to start a cab from scratch!). I left in this cab her black soft keys reg edit to match the theme.
edit...zip/cab to large to post! Hold!!
TreeFrog is online now
Old 11-15-2008, 12:19 AM   #33 (permalink)
TreeFrog's Avatar
K...download here!
after install..select start..settings..homescreen:
eBdesign - Halo 3
default
default
never
(scott...call me!) =)
The Following User Says Thank You to TreeFrog For This Useful Post:
fatality (11-20-2008)
Old 11-20-2008, 09:54 AM   #34 (permalink)
fatality is on a distinguished road
Originally Posted by dafoxs View Post
the one thing about facade, it creates a hidden temp. HS of the one you are using. You can drive youself crazy untill you get rid of it.
yeah, i don't really like facade. can anybody direct to some cab themes...
fatality is offline
Old 11-22-2008, 04:08 PM   #35 (permalink)
relisted is on a distinguished road
Send a message via AIM to relisted
Rating or review
Originally Posted by Tenchistyle View Post
The .zip file contains an .xml that will display both a calendar and a task screen, and another that only displays a calendar screen. A few screen shots are attached below. All images need to be placed in a folder titled "eb" within the same directory as the other .xml home screen files. Enjoy!
http://www.lollicupwaterford.com/Halo3_Theme.zip
P.S. If ya like it, please give thanks!
Requires Facade (will display properly w/o Facade, but is less functional)
awesome!!!
anyway i could ask for a gears of war 2?
i prefer the character ty. lol just in case haha
d[-_-]b
relisted is offline
