Old 04-07-2008, 02:07 AM   #411 (permalink)
Justinxpx109 is on a distinguished road
Thanks a lot. These are awesome. Lakers and Dodgers 08 Champs!
Justinxpx109 is offline
Old 04-07-2008, 08:21 AM   #412 (permalink)
tk15 is on a distinguished road
Golden...Can you use the Caddy logo with the other homescreen...The one you do with all the sports logo's?
Also, what jpg do I add to my phone to use this screen..Do I need to add a plug-in in to get this to come together...thanks
tk15 is offline
Old 04-07-2008, 01:37 PM   #413 (permalink)
Once unRARed, place the XML file and the folder with the images (intact) into the Home folder.
The Following User Says Thank You to Golden Y For This Useful Post:
tk15 (04-08-2008)
Old 04-08-2008, 08:49 AM   #414 (permalink)
Golden...thanks...then I just select default as the background...very nice...
tk15 is offline
Old 04-08-2008, 06:20 PM   #415 (permalink)
jacksonian is on a distinguished road
Originally Posted by Shlov1 View Post
Can someone please help me with this one? I downloaded this, opened it and installed it into my home folder. Then when I go to select that homescreen the background comes up white. Everything is set to default, but I can't get it to work. Can someone please help me? Thank you in advance.
I'm also having this problem with any of the screens that have multiple images. The neutron, gyp abstract, etc. that only have 2 files work great on my Q, but any of the others with 5-6 jpgs and the xml file show up as white.
any advice? I'd love to have the GYP Clean ones. they look fantastic!
jacksonian is offline
Old 04-08-2008, 06:23 PM   #416 (permalink)
eko
eko is on a distinguished road
make sure that if there are multiple images that you keep them in the folder that that the came in, usually you will have a xml file and an image that you place in the application data/home folder with multiple image homescreens you have an xml and then a folder containing all the images. If you change the name of that folder or you take the images out of it you will see a blank screen. so make sure you place the xml and the folder in the application data/home folder
eko is offline
Old 04-08-2008, 06:32 PM   #417 (permalink)
thanks so much! worked like a charm.
Old 04-09-2008, 06:43 PM   #418 (permalink)
inscracefan24488805's Avatar
inscracefan24488805 is on a distinguished road
Smile Trying to get a special Colorado Rockies Homescreen
I'm trying to get a special Colorado Rockies Homescreen for my Motorola Q that incorporates the Facade and Fizz Weather plugins. I had this on the wallpapers forum and someone on that thread suggested that I try posting in this thread.
Anyone who wants more details about what I would love to have can click here.
I want this for my nephew's t-ball games. He would think that this is so cool that I would have this for my phone. So if anyone can please help me out here, I would definitely appreciate it a lot.
Cindy
inscracefan24488805 is online now
Old 04-10-2008, 12:21 PM   #419 (permalink)
Wheelman is on a distinguished road
I tried those values and it makes the green look washed out. I might try a more vibrant green....
Could you possibly do a screen with the Astros?
Wheelman is offline
Old 04-10-2008, 01:59 PM   #420 (permalink)
mrsalsays is on a distinguished road
hey, i requested a yankee wallpaper back on the 8th page, i guess youre busy
mrsalsays is offline
