Originally Posted by LordZeus Thanks buddy  |
Originally Posted by n99hockey you need the all day plugin |
I edited the calendar plugin on the cubs HS with the all day plugin i found, works. Although if i dont have an all event, it doesnt say anything. How do i get it to say "No events today...Master"
F.Y.I I dont have the calendar plugin installed cause it shifts the HS up cause the calendar pluging in shown under the all day, instead "replacing"
<!-- All Day Event plugin-->
<plugin clsid="{2FFD93B3-0FF0-4228-A6D6-D2DF177D7D92}" name="alldayevent" height="23">
<background>
<format state="noevent" visible="false"/>
</background>
<label h="23">
<format state="unselected" font-weight="bold" />
<format state="selected" font-weight="bold"/>
<text><subject/></text>
</label>
</plugin>
*<format state="noevent" visible="false"/>
I tried "true" same result.
