Old 12-07-2007, 10:26 AM   #1 (permalink)
blaidan is on a distinguished road
Default Getting a Q9c - Will most of these home screens work/
Sorry if this is a dumb question. I just didn't know if the Q9c's Windows 6 was going to be an impediment to running the home screens previously being run on the original Q.
I am going to be getting a Q9c soon. I currently run the "Black Vista" theme as my home screen on my Q. Will that home screen work on the Q9c?
TIA for any input!
blaidan is offline
Old 12-07-2007, 10:30 AM   #2 (permalink)
TIA for any input!
as long as you have all the plugins (facade, etc.) that the screens require then they will work
Old 12-07-2007, 10:34 AM   #3 (permalink)
Excellent! Thanks for the quick response.
I guess that begs the question.... are there different versions of the various plugins (Facade, Fizz Weather) for Windows Mobile 6 that I would have to purchase or will the current version I use for Windows Mobile 5 work just fine?
blaidan is offline
Old 12-07-2007, 10:36 AM   #4 (permalink)
i would check with there site to make sure
but i think it should
blaidan (12-07-2007)
Old 12-07-2007, 10:40 AM   #5 (permalink)
Thank you for the fast replies!
blaidan is offline
Old 12-07-2007, 10:42 AM   #6 (permalink)
no problem!!!
Old 12-07-2007, 10:55 AM   #7 (permalink)
Prosper's Avatar
There shouldn't be a problem with WM5 software on a WM6 device. WM6 handles the PIM things a bit different I think, but most softwares can already handle that (Facade e.g. can).
Prosper is offline
The Following User Says Thank You to Prosper For This Useful Post:
n99hockey (12-07-2007)
Old 12-07-2007, 11:11 AM   #8 (permalink)
I was assuming there shouldn't be an issue but wanted to be sure. Thanks.
blaidan is offline
Old 12-07-2007, 10:27 PM   #9 (permalink)
xnight is on a distinguished road
And we also make WM6 HS's here too, in case you didnt know
If any of mine work for ya i can change them to WM6
xnight is offline
