Old 06-18-2008, 06:47 PM   #1 (permalink)
Brent372's Avatar
Brent372 is on a distinguished road
Default Ford Homescreen
Can somebody make a Ford homescreen using the Ford oval?
Blue theme would be awesome.
I don't care too much about calendar so it can be left off.
No plug-ins please.
Brent372 is offline
Old 06-18-2008, 07:12 PM   #2 (permalink)
kaylabeers's Avatar
kaylabeers is on a distinguished road
I will throw something together right now =)
kaylabeers is offline
Old 06-18-2008, 07:55 PM   #3 (permalink)
kaylabeers's Avatar
Default Ford Home Screen
Download in my home screen collection.
Old 06-18-2008, 08:05 PM   #4 (permalink)
Brent372's Avatar
What is a tgz file?
Where do I get Elko's icons?
Brent372 is offline
Old 06-18-2008, 08:18 PM   #5 (permalink)
kaylabeers's Avatar
Where are you finding a TGZ file? It should be a RAR [open up in Winzip or WinRAR], copy the two files [one being a XML and the other a JPG], in your Application/Home directory. If it is a TGZ file, open it up in Winzip or WinRAR and see if it will get you those two files.
You don't need to worry about getting Eko's icons, I just wrote that to give her credit, they are built into the background image.
If you need more help, I am heading to work right now, but will be back around 10PM. If you don't want to wait that long, I am sure someone else can help you.
Old 06-18-2008, 08:38 PM   #6 (permalink)
docmac129's Avatar
Originally Posted by Brent372 View Post
What is a tgz file?
Here is where u get Eko's Black Soft Keys as shown in the HS capture Kayla did for u. Just download black cab file and install on q.
Just unzip HS file like Kayla said and put all files into Application Data>home on Q.
docmac129 is offline
The Following User Says Thank You to docmac129 For This Useful Post:
kaylabeers (06-18-2008)
Old 06-18-2008, 08:43 PM   #7 (permalink)
kaylabeers's Avatar
Thanks for helping me assist him. Now I should go to work before I am late =)
Old 06-18-2008, 09:14 PM   #8 (permalink)
docmac129's Avatar
No problem Kayla, & very nice screen!!
Old 06-20-2008, 10:10 PM   #9 (permalink)
Brent372's Avatar
Thanks !!!!
Love the homescreeen
Brent372 is offline
Old 06-21-2008, 01:29 AM   #10 (permalink)
kaylabeers's Avatar
Glad you like it. =)
