Old 09-27-2007, 12:42 PM   #41 (permalink)
yankeesji is on a distinguished road
Smile
Originally Posted by Der Alta View Post
This would be great if she was still hot
yankeesji is offline
Old 09-27-2007, 09:06 PM   #42 (permalink)
cmva is on a distinguished road
if you know the names.. they might be here.
I got nothing but that I'm not supposed to be there!. Oh well...
cmva is offline
Old 09-30-2007, 03:38 PM   #43 (permalink)
frosty1 is on a distinguished road
where do u get the addons ons to install these home screens?
when i try to install it, i cant see the picutre but can see the time and the other things..
frosty1 is offline
Old 09-30-2007, 03:53 PM   #44 (permalink)
copy the image that is on the site (posted with the xml file) and then copy it to your \application data\home folder
also make sure in your homescreen settings on the Q that the background image is set to default
Old 09-30-2007, 04:10 PM   #45 (permalink)
ya i did copy the image file and the xlm to that folder, and yet i still cant get the image but get everything else?
and yes its all set to default
frosty1 is offline
Old 09-30-2007, 04:26 PM   #46 (permalink)
check the xml file to make sure it has the right path and file name (it should but just to be sure)
Old 09-30-2007, 04:35 PM   #47 (permalink)
when i look on the phone to see where the stuff is at it says its in the my documents/pictures folder?
i didnt send it there i send it to the app data/home via bluetooth since im on a Mac. but when i do check under app data/home the stuff is in there... the .xml is atleast
is that the problem?
if so how do i fix this?
frosty1 is offline
Old 09-30-2007, 04:40 PM   #48 (permalink)
move the image
well they both need to be there
not only does the xml file need to be there the image does to so the \application data\home folder
Old 09-30-2007, 05:08 PM   #49 (permalink)
ok i dont know y but the jpg just wont go to the home folder it just goes to the my documents folder??
frosty1 is offline
Old 09-30-2007, 05:51 PM   #50 (permalink)
well if its on the Q then use the file manager on the Q to move the file to the correct location
