Old 09-13-2007, 06:54 PM   #21 (permalink)
I usually start with 640x480 and then reduce it after I've got my image laid out. I add the finishing touches (overlays, meshes, opacity) at the regular size (320x240).
Der Alta is offline
Old 09-13-2007, 09:42 PM   #22 (permalink)
Originally Posted by Bert336 View Post
what do u mean? hit me up on AIM: Intranceweetrust
i will, if need be.. i appreciate it man.
and also thanks to you.
Old 09-13-2007, 10:52 PM   #23 (permalink)
just wondering...
why do you start with the images oversized?
Old 09-14-2007, 07:42 AM   #24 (permalink)
Bert336's Avatar
Bert336 is on a distinguished road
I think he does it so he can see the detail better...for instance when doing it on a 320x240 and zoom in the detail isn't as sharp since the pixels are being blown up to the max.. that would be my guess lol
Bert336 is offline
Old 09-14-2007, 07:46 AM   #25 (permalink)
i was thinking the same and that is also the reason i did it w/ what i was doing...
Old 09-14-2007, 12:21 PM   #26 (permalink)
that makes sense...good thought!
Old 09-14-2007, 12:47 PM   #27 (permalink)
Prosper's Avatar
Not sure what you're exactly trying to do, if you already got it or whatever, but I think I can drop some general PS skinning thoughts here since it's already getting a bit OT
1. I start with a 320*213 image (File -> New)
2. Open the image you want as background image
3. Copy it into the 320*213 image
4. Resize/Position with Strg+T (Free Transforming)
Then add windows/style etc in the 320*213 image.
Just my 2 cents.
BTW I'm working with PS CS3. Those steps should work with all PS versions, and also GIMP I think.
PS: This is just how I'm handling Landscape only skins... Vox ones are a bit more complex, but I guess you don't mind about that :D
Prosper is offline
Old 09-15-2007, 10:51 AM   #28 (permalink)
That is why I start working at a bigger scale. Doing the layout and the opacity/combination and working the layering and effects out, goes much easier at a larger scale.
Its also much easier to hide mistakes at a large scale, so they aren't seen at a smaller scale.
Der Alta is offline
n99hockey (09-15-2007)
Old 09-15-2007, 01:15 PM   #29 (permalink)
Its also much easier othide mistakes at a large scale, so they aren't seen at a smaller scale.
cool ill have to give that a try
