Old 07-01-2007, 11:12 PM   #1 (permalink)
illuzionn is on a distinguished road
Default For all you honda fans.. if there is any
like a lot of people i recently just got my motorola q. and the thing ive notice is that there isnt a lot of homescreen layouts to pick from. although there are sites out there with plenty of nice homescreens but just not any that i liked. so i decided to create my own. this is my first attempt in making one, and now ima share it with you guys. tell me what you think and if theres any errors that i did let me know. its just a simple homescreen. check it out.
:::::::::EDIT::::::::::
http://www.badongo.com/file/3619198
^^ NEW LINK, now you do not have to wait anymore. sorry about previous link.
NOTE: To install unzip all files in zip (in this case the XML file it self and a "Honda" folder which holds the selected and unselected buttons also) and place them in "Application Data/Home" using active sync.
After go to "Settings" on your phone and then select "Honda" as your homescreen
Make sure that both "Color Scheme" and "Background Image" is set to default.
If you have any problems let me know.
EDIT:
illuzionn is offline
Old 07-02-2007, 03:08 AM   #2 (permalink)
does anyone know how i can take a screen shot of the homescreen on my phone? if so i can show you a better example of how it looks like the image i provided above looks plain and boring... thanks
Old 07-02-2007, 05:55 AM   #3 (permalink)
Pony99CA's Avatar
Default Search!
Did you search on screen capture? If so, you would have found the Screen Capture thread.
Steve
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
Old 07-02-2007, 06:29 AM   #4 (permalink)
Smile
Steve
haha thanks a lot! newb to the forum as you can tell.
Old 07-02-2007, 06:56 AM   #5 (permalink)
Pony99CA's Avatar
Default Newbie?
Maybe, but at least you're contributing something already with a Home screen. I'll give you a rep boost for that.
Steve
Pony99CA is offline
Old 07-02-2007, 08:23 AM   #6 (permalink)
nice work.. too bad the car is blocking the background <jk> :}
Old 07-02-2007, 08:27 AM   #7 (permalink)
great job!!
keep it up!
Old 07-02-2007, 01:07 PM   #8 (permalink)
thanks for all the feedbacks guys ! right now im working on a few ill post it up as soon as im done.
