Description: Are you tired of the fonts on the Sliding Panel Home Screen and your boring System Fonts? This cab file will install and enable a set of fonts for use in your Blackjack with WM 6.1. By default it will set the system font and sliding panel fonts to "Poor Richard" (because I like how that looks. Make sure you backup your Chome_320x240.cpr file prior to installing this cab. Instructions are included in the install folder for manually changing the fonts to others that you may have or the other fonts included with the program.
download:
http://mq.roeiboot.com/apps/Q9_specific/FontChange.CAB
