Originally Posted by manbat Has anyone gotten these added Icon changes to work?.....I thought I was on the right track......but I couldn't get them to work. If the icon is already in the phone ...I've been able to use it in other folders....but that's as far as I got. |
If you follow the directions in the link that was previously posted it works. I modified almost every icon on my Q9c. I used GConvert 5.0 to build the icon libraries. They HAVE to be 48x48 256, 32x32 256 and 16x16 256. Using true color icons will not work. Found that out the hard way after building the library and changing about 25 of the icons. Put the icon library in your windows folder and make the changes to the "lnk" file. I just did a hard reset last night for an unrelated reason, but I will redo some of my changes and post a pic.
The quick and dirty: Rename the icon.lnk file to icon.txt and edit the contents. The syntax should be as follows:
1#name.icl,-3
As described in the other thread, the first number doesnt mean much. The "name.icl" should match your library and the "-3" is the respective position of the icon within the library. After all changes are made, rename the file to "icon.lnk" and you should be good. Now, the change will not be immediate but if you go into the start menu and navigate to the folder you are trying to change, you will see the icon.lnk in the menu. Click on it and it should register the library asking if you are sure you want to run the component. Just say yes. THEN, a soft reset is normally required. Seems like a lot of work, but once youve done it a few times it goes pretty quick. By the way, once your library is registered, you wont have to reset everytime you change a folder or program to use the icons within the library. Sorry if this a bit confusing, im no teacher. I will post how to change program icons later, but i think that is also covered in the other thread.
I believe Munan was the first to post this many moons ago, props go to him.
