Old 05-07-2007, 03:21 PM   #11 (permalink)
oddllama's Avatar
oddllama is on a distinguished road
i added that snippet in a few places but nothing. it was working at firt but after trying to tweak the tab positions it whacked out on me. i can scroll through the icons but it doesnt show the selected icon.
I'll try some more later toay.
thanks again.
(first post from th Q!)
oddllama is offline
Old 05-07-2007, 03:30 PM   #12 (permalink)
alright keep us updated!
Old 05-07-2007, 06:09 PM   #13 (permalink)
shaun0207's Avatar
shaun0207 is on a distinguished road
Send a message via MSN to shaun0207 Send a message via Yahoo to shaun0207
Let Me Know What You Think
shaun0207 is offline
Old 05-07-2007, 06:16 PM   #14 (permalink)
shaun0207's Avatar
Default Superman Theme
message window
Old 05-07-2007, 06:22 PM   #15 (permalink)
shaun0207's Avatar
Inside Menu
Still couldnt change the start menu, but I think it came out pretty good. I would to turn the start and contacts soft keys red.
Old 05-07-2007, 08:19 PM   #16 (permalink)
oddllama's Avatar
check to see if your launcher code or MRU code has this...
max-buttons="X"
and where the X is put the number of icons you want...i think that should do it
is there a way to remove the icons from the tabs so that I just have the text labels (i.e. Tasks, Launcher, etc.)?
oddllama is offline
Old 05-07-2007, 08:25 PM   #17 (permalink)
oddllama's Avatar
Originally Posted by shaun0207 View Post
Inside Menu
It's a bit colorful for my tastes, the contrast makes the text a bit hard to read. Good job though.
Thread Jacked! lol
oddllama is offline
Old 05-07-2007, 08:29 PM   #18 (permalink)
oddllama's Avatar
One more question concerning theme making:
Is there an easy way to find pixel location? I find myself constantly moving things around a few pixels at a time trying to get it right. I use photoshop to create the images and tried using the rulers for reference. While it's somewhat close sometimes, it is a pain to reload the skin 100 times to see if something is in the right place. The image anchor seems to affect the placement as well (top, bottom, etc.) Is there a hint or rule of thumb for gauging placement? Thanks for any info.
oddllama is offline
Old 05-07-2007, 10:25 PM   #19 (permalink)
Inside Menu
nice work!!
Old 05-07-2007, 10:26 PM   #20 (permalink)
looks like you need to edit the jpg images that are used for the tabs....
