Old 10-05-2007, 03:28 PM   #31 (permalink)
Originally Posted by Ms.Rip View Post
It doesn't give me that option...I click on "Get Homescreen" and nothing happens
Which homescreen editer/builder would you recommend?
Sorry another question...I was going through some homescreens on this website and I wanted to use one...So I "right clicked" and "saved as"...What do I do next?
im not sure where you saw 'get homescreen' but those editors arent that great
if you saved as from our site make sure you verify the file extension. if its a cab file move the entire file from the PC to the Q
if its a zip file unzip the file and move the xml file and the jpg image inside of the zip file to the
\applciation data\home folder on your Q then go to
start
settings
homescreens
and select the screen you just loaded
Old 10-05-2007, 03:31 PM   #32 (permalink)
Ms.Rip is on a distinguished road
Send a message via AIM to Ms.Rip
Ok, let me try! Thank You so much!
If it's a cab, do I move it anywhere??
It says "Installation of (homescreen name) was unsuccessful. The installation file is not intended for this device"...
Ms.Rip is offline
Old 10-05-2007, 03:34 PM   #33 (permalink)
no problem good luck!
Old 10-05-2007, 03:39 PM   #34 (permalink)
Stealth's Avatar
Stealth is on a distinguished road
Originally Posted by glstnng319str View Post
Jen-Bunny is a nick name for me because my name is Jen. It wasn't really my birthday I just haven't been able to figure out how to have the XML show the "no upcoming appointsment" when I don't have any so i just made one up to show where the calendar goes. Maybe because I'm just using all day event plug in and not calendar plug in. Either way if you know how to make that show up when i don't have any all day event please let me know. I'll post all the other ones with a link for all. Thanks again for the feed back
Jen Bunny... The Hills??????
Sprint Moto Q user
Stealth is offline
Old 10-05-2007, 03:40 PM   #35 (permalink)
haha...Yeah, I was about to say that...
Ms.Rip is offline
Old 10-05-2007, 03:42 PM   #36 (permalink)
Doesn't work....This is what it says ^^
Ms.Rip is offline
Old 10-05-2007, 03:44 PM   #37 (permalink)
what screen are you trying to install and where did you get it?
Old 10-05-2007, 03:46 PM   #38 (permalink)
http://www.everythingq.com/forum/q-h...ens-11783.html
It's the green matrix one...From Del Alta's homescreens...
Ms.Rip is offline
Old 10-05-2007, 03:57 PM   #39 (permalink)
i dont see green matrix on his page
Old 10-05-2007, 04:08 PM   #40 (permalink)
glstnng319str is on a distinguished road
i am not tha jen bunny but thats where my friend got the name from. someone needs t explain to me how to post the file name so you guys can put it in the collection.
glstnng319str is offline
