| Notices | Thank you for visiting the Everything Q forums, the #1 Moto Q community in the world. To get the most out of your experience, please take a moment to register. Registration is free and you'll receive a coupon code to save 20% off Moto Q software. Other member benefits include: - Faster and easier to search the forums.
- Receive notifications regarding topics of interest.
- Send and receive personal messages with other members.
- Take advantage of our social networking capabilities.
- View photos that appear in forum topics, including free Q homescreens and wallpapers.
- Download free Moto Q software.
- See less ads!
- Many more benefits...
Click here to register! |
05-17-2007, 12:56 PM
#1 (permalink)
| Facade Question I downloaded Facade and it came with 2 themes... regular and wide.. I like the layout and want to keep it.. is there a simple way to change the background? I'm fluent in design software but am new to XML if that's the case. I just wanna change the background.. keeping all the tabs and everything.. any info would be great thanks! |
05-17-2007, 01:07 PM
#2 (permalink)
| | Super Moderator
| you can load an image to your \application data\home folder and then in the facade settings for that xml you are using (whatever it may be) the first line says 'background image' and has the path of an image...hit the center button over this path and a list of images in that \application data\home folder appear and then you can select whatever image you want...you should be all set....hope that helps |
05-17-2007, 01:41 PM
#3 (permalink)
| sounds helpful.. i'm away from my data cable but that gives me a bit of hope.. is there any way to change the shortcut icons or get rid of a few in facade? some of them I don't even use |
05-17-2007, 01:46 PM
#4 (permalink)
| | Super Moderator
| you do that straight from your phone no need to hook it up to the computer.
the shortcut icons you would need to edit the actual xml file from your PC... |
05-18-2007, 07:08 AM
#5 (permalink)
| thanks for the help!!! |
05-18-2007, 07:37 AM
#6 (permalink)
| | Super Moderator
| no problem!!!!!
- Sent from my Q |
05-18-2007, 07:51 AM
#7 (permalink)
| Both the bacground image and Facade Launcher (shortcut) buttons can be set up from the Facade settings progam--no need to edit the xml (unless you want to). |
05-18-2007, 08:06 AM
#8 (permalink)
| | Super Moderator
| really?
i never noticed that option....ill have to look for that one! |
05-18-2007, 08:14 AM
#9 (permalink)
| The first item when you enter the Settings program is the backgrounds image selector. For Launcher buttons, go to Menu, Launcher, Buttons. |
05-18-2007, 08:26 AM
#10 (permalink)
| | Super Moderator
| i knew about the background image but never noticed that...thanks |
| | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:59 AM. |
