Old 05-22-2008, 03:21 PM   #1 (permalink)
keenan6 is on a distinguished road
Default Facade?
Hey Guys
This is my first PDA and I'm really new when it comes to customizing the Q
I downloaded a couple of home screens from the collection you guys have up and they work just fine. I keep running into a problem with a few of them since they will not display in my settings. They seem to be missing the "image" file on each download. Do I need facade for this? if yes, where can I download the facade? and which folder of the Q do I need to make sure it's copied to?
keenan6 is offline
Old 05-22-2008, 03:23 PM   #2 (permalink)
Originally Posted by keenan6 View Post
Hey Guys
which are you trying to get to work?
does it say 'requires facade'?
Old 05-22-2008, 03:27 PM   #3 (permalink)
http://ekopapers.com/os.htm
None of the home screens from that site work for me...
keenan6 is offline
Old 05-22-2008, 03:31 PM   #4 (permalink)
some do require facade and some dont
the ones that do say need facade under the image
also read this from her site on how to install the screens
http://ekopapers.com/install.htm
sounds like you are missing something when you are installing
Old 05-22-2008, 03:44 PM   #5 (permalink)
Ah I see ... thanks for the link.
What do I need the cab file for? I have a few home screens installed w/o doing the "cab" steps.
keenan6 is offline
Old 05-22-2008, 03:46 PM   #6 (permalink)
if you read the link the cab file is the install file for the homescreen
you dont unzip it you just load that to the Q and click on the file with the center silver button to install it
Old 05-22-2008, 03:53 PM   #7 (permalink)
Oh ok cool
thanks for the help! i will give this a shot tonight!!
keenan6 is offline
Old 05-22-2008, 03:53 PM   #8 (permalink)
Oh ok cool
ok good luck
Old 05-23-2008, 12:42 AM   #9 (permalink)
ok
I followed the steps from the link, but the .cab file doesn't install like it says it should. I copied it into the start menu and after selecting it on the Q it just shows me the HTML file, does not install
keenan6 is offline
Old 05-23-2008, 01:24 AM   #10 (permalink)
mike250rs's Avatar
most screens have 2 or 3 files with them.
you should have..
xxxxx.home.xml
make sure these files are in the \application data\home folder
mike250rs is online now
