Old 05-23-2008, 02:22 AM   #11 (permalink)
keenan6 is on a distinguished road
Originally Posted by mike250rs View Post
most screens have 2 or 3 files with them.
you should have..
xxxxx.home.xml
make sure these files are in the \application data\home folder
Yes, exactly
every home screen I download from that site has 4 files, none of them are jpg or home.xml like they normally are.
keenan6 is offline
Old 05-23-2008, 07:18 AM   #12 (permalink)
Tony Bag o Donuts's Avatar
If its a cab file, you have to select it in file manager on the phone and it will install it for you.
A cab is a wm zip file.
My photography website.
leave comments, etc.
Tony Bag o Donuts is offline
Old 05-23-2008, 04:14 PM   #13 (permalink)
Originally Posted by keenan6 View Post
Yes, exactly
verify the file extension...like tony said...its probably a cab file which is NOT a zip file but an install file
Old 05-23-2008, 05:43 PM   #14 (permalink)
my bad...easy association for me.
Old 05-23-2008, 08:07 PM   #15 (permalink)
SilkSurgeon is on a distinguished road
I am tryin to install home screens that require facade. I have facade on my phone but the background never displays properly. what am I doing wrong settings wise? I only change home screen layout, color scheme and bg image stay the same...it NEVER works. It always messes up or says "the layout you selected" and I can't see the rest...what am I doing wrong?
SilkSurgeon is offline
Old 05-24-2008, 12:07 AM   #16 (permalink)
Papasmurf699 is on a distinguished road
umm where would I get facade? I wouldnt mind getting it. I googled it and I got something strange that has to do with tarot card readings. so ummmmmm if someone wouldnt mind posting up a link where I could get it, that'd be pretty well appreciated
Papasmurf699 is offline
Old 05-24-2008, 12:20 AM   #17 (permalink)
mike250rs's Avatar
have you tried the software store here?
http://software.everythingq.com/prod...le.asp?id=7010
mike250rs is online now
The Following User Says Thank You to mike250rs For This Useful Post:
Papasmurf699 (05-24-2008)
Old 05-24-2008, 12:21 AM   #18 (permalink)
argh, lame. I didnt know it cost money :P haha
thanks anyways!
