Old 09-07-2008, 09:11 PM   #421 (permalink)
blcistheking is on a distinguished road
Ok thanks geekster & eko for creating the theme
blcistheking is offline
Old 11-03-2008, 10:14 AM   #422 (permalink)
psykotic24 is on a distinguished road
Default New to this
I have an issue with ekoflip vista. I literally have no clue whatsoever as to how to apply the multiple backgrounds associated with each panel. under facade the only thing I can do is select one background, but there are like 4 or 5. Any help would be greatly appreciated. Thanks in advance!!
psykotic24 is offline
Old 11-03-2008, 10:29 AM   #423 (permalink)
brandon.roeder's Avatar
brandon.roeder is on a distinguished road
as far as i know..you cant use different backgrounds for each "panel"
brandon.roeder is offline
Old 11-03-2008, 11:54 AM   #424 (permalink)
docmac129's Avatar
If u are asking about the stock backgrounds that she created, u DON'T have to apply the individual backgrounds in that particular HS. Just download that HS from her site, and drag both the Ekoflipv folder & the ekoflipv.home.xml into the Application Data>home file on the Q. All the backgrounds are in the folder and the xml finds the backgrounds automatically by looking for them in that folder. Just make sure when u drag the folder over that u see a folder called ekoflipv in application date>home. Then just go select it under the settings>homescreen section.
docmac129 is online now
Old 11-03-2008, 12:05 PM   #425 (permalink)
eko
eko is on a distinguished road
if you want to use a different image they have to be created with the overlays on them and then replaced on the actual phone if that makes sense
yea, Kay is correct.. Eko is tied up (not literally) with moving and taking care of the youngin's (kids :}
hmmmm although the alternative sounds like it could be fun ;) jk yeah the kiddos have been keeping me very busy and we also had a very large fast move this summer We are all settled in our new place so I may begin taking request via email again and Ill be popping my head in here from time to time again
Originally Posted by dudebro View Post
by any chance, can you make a simple one? without a superhero. something like a vista background or something. would be much appreciated.
hopefully one of these will do for you
eko is offline
Old 11-03-2008, 12:16 PM   #426 (permalink)
your back!
Old 11-03-2008, 12:38 PM   #427 (permalink)
glad to see your still popping in Eko!!
Old 11-03-2008, 12:45 PM   #428 (permalink)
eko
glad i can pop in from time to time, i miss working on homescreens when life sweeps me away lol
eko is offline
Old 11-03-2008, 01:01 PM   #429 (permalink)
ekooooooooooooooooooooooooooo !! :}
Old 11-03-2008, 03:47 PM   #430 (permalink)
Geekster's Avatar
eko bbbaaaaaaaaabbbbbyyyyyyyy!!!!!!!!!
Glad you popped in for a few minutes...
Glad everything is OK with you and family.
Don't stay gone so long OK?
It's not that I'm so different from other people.
It's just that long ago I stopped being the same and over the years it added up.
http://www.frappr.com/?a=constellati...d=137440517530
Geekster is offline
