Old 05-05-2008, 11:03 AM   #331 (permalink)
xalias51's Avatar
xalias51 is on a distinguished road
The problem is the graphic name in the xml file does not match the actual name of the background graphic. I pointed this out in a post on page 14 of this thread. Guess EKO hasn't gotten around to correcting the download.
You can fix this by opening the xml file in a text editor and changing he graphic name from blacksf.jpg to blacks.jpg.
At least, this sounds like the same problem I was having.
xalias51 is offline
Old 05-05-2008, 11:57 AM   #332 (permalink)
smithph is on a distinguished road
Bingo! Thank You
smithph is offline
Old 05-05-2008, 12:24 PM   #333 (permalink)
eko
eko is on a distinguished road
just wanted to let you guys know I just fixed the xml recreated the cab and posted it. If you previously downloaded it and want to use the new cab, go to your settings > remove programs > and then uninstall it. Download the new cab file put it on your phone and run it. It should then work. Sorry about the inconvienence ~ellie
eko is offline
The Following User Says Thank You to eko For This Useful Post:
smithph (05-05-2008)
Old 05-12-2008, 10:46 AM   #334 (permalink)
eko
Default bb9000
this is based off of blackberrys 9000 aka BOLD phone. Missed calls screen only shows if you have a missed call
Requires facade
click here to dl
eko is offline
Old 05-13-2008, 03:14 PM   #335 (permalink)
eko
Default F4U Corsair
F4U Corsair - No Plugins required
click here to dl
eko is offline
Old 05-13-2008, 03:38 PM   #336 (permalink)
relisted is on a distinguished road
Send a message via AIM to relisted
awesome eko! thanks!
relisted is offline
Old 05-13-2008, 03:39 PM   #337 (permalink)
one request :D
ur shrooms background.. without facade.? wanna help a fellow member out
relisted is offline
Old 05-13-2008, 05:16 PM   #338 (permalink)
eko
if its that layout you want I wont be doing that most likely if you just want something with that background that could probably be aranged.
Dale Jr. #88
click here to dl
eko is offline
The Following 2 Users Say Thank You to eko For This Useful Post:
chervon88 (05-13-2008), MyAGunn (05-13-2008)
Old 05-13-2008, 05:32 PM   #339 (permalink)
well anything with that background. just NO pluins :D pweeze TIA
relisted is offline
Old 05-13-2008, 07:51 PM   #340 (permalink)
nahzekology is on a distinguished road
Default Blackberry HS
Requires facade
click here to dl
is there any way the master of homescreen creation could cook up as HS that looks like the Sprint's Blackberry Curve?
Is this possible? And if so can it be done without the orange plugin?
I also have facade.
Thank You!
nahzekology is offline
