Originally Posted by JBK617 I believe I had to go into Pocket Weather settings/icons and set them to tiny and then did soft reset and they showed up in Facade. If that doesn't help I saw a users guide on the Pocket Weather Page today |
Thanks for the reply JBK617. Unfortunately, setting all of the icons in Pocket Weather to tiny and then doing a soft reset still does not resolve the issue of the weather not showing up in the calendar.
I took a look at the user guide on the Pocket Weather page and it basically says to set the "Weather Style" in Facade, something that I have already done.
So I clicked around and in Facade options there is a Plugin selection and in the plugin list, there is Weather Plugin so I checked that box and still no weather in the Calendar.
Any other ideas?
