Old 08-20-2007, 07:58 PM   #1 (permalink)
oldnavycb is on a distinguished road
Default Eko home screen help
I was on eko's page and was very interested in one of the homescreens but when i click it all I get is a page of coding, I am not sure how to get the screen onto my Q and set as my home screen can anyone fill me in...
oldnavycb is offline
Old 08-20-2007, 08:00 PM   #2 (permalink)
which one is it ? i tried a few and have no problems.. are you browsing with a pc or with the Q ?
Old 08-20-2007, 08:38 PM   #3 (permalink)
ekos homescreens are in cab format
just download the one you want...save it to the PC transfer it to the Q and install it like a program and your all set
Old 08-20-2007, 08:45 PM   #4 (permalink)
I do not know how to dowload it off the site or how to set it once it is on my phone...sorry im so stupid when it comes to this
Old 08-20-2007, 08:50 PM   #5 (permalink)
another thing I have a file i dowloaded from kooldezines in my documents on my fone it is called motorolawhite.zip I just have no clue how to set it as my home screen
Old 08-20-2007, 08:51 PM   #6 (permalink)
unzip the file
put the .xml file and any .jpeg files or folders on your Q in the \application data\home folder
then go to start--settings--homescreens and select your screen
make sure that you keep the color scheme and background image default no matter how much you want to change it...dont!
oldnavycb (08-20-2007)
Old 08-20-2007, 08:58 PM   #7 (permalink)
how do i unzip??
Old 08-20-2007, 09:16 PM   #8 (permalink)
how do i unzip??
either use winzip or the windows unzip program
right click on the file and look for something that says winzip/unzip/windows zip (compress) or something like that...dont remember what windows one is called
www.winzip.com
thats winzip...you can download it there if you wanted
Old 08-20-2007, 09:17 PM   #9 (permalink)
Do i need some sort of special software to unzip the file?? I have searched the phone and found no such way to unzip
Old 08-20-2007, 09:19 PM   #10 (permalink)
you do it on the PC
i just posted a link in my previous post
www.winzip.com
