Old 05-18-2007, 01:43 PM   #1 (permalink)
Hitokiri's Avatar
Hitokiri is on a distinguished road
Default Edit Missed calls?
How can I edit the missed calls screen?
Hitokiri is offline
Old 05-18-2007, 02:06 PM   #2 (permalink)
edit it to do what?
Old 05-18-2007, 02:20 PM   #3 (permalink)
Hitokiri's Avatar
edit it to do what?
to replace it with my own screen and position the txt of course!
Hitokiri is offline
Old 05-18-2007, 02:25 PM   #4 (permalink)
HAHA i should have known...
does your screen already have the missed call screen plugin?
if so you just create an image just like you would for a background and in the plugin you direct it to that image in the \application data\home folder...
make any sense?
Old 05-18-2007, 03:09 PM   #5 (permalink)
Hitokiri's Avatar
make any sense?
no
Can you give me the code?
Hitokiri is offline
Old 05-18-2007, 03:30 PM   #6 (permalink)
here you go
<!--standard missed calls plugin-->
<plugin clsid="{0BA8ABB8-1F1D-417f-88C6-DA8530E2E7A6}" name="missedcalls" height="220">
<background bgimage="XXXX.jpg" valign="top" b-border-width="0">
</background>
<format state="nocall" visible="false"/>
<label h="22" bgcolor="transparent" fgcolor="#FFFFFF">
<format state="unselected" font-weight="normal" />
<format state="selected" font-weight="bold" fgcolor="#FFFFFF" />
<text lang="0x0409">
Missed calls: <calls/>
</text>
</label>
</plugin>
Old 05-18-2007, 03:46 PM   #7 (permalink)
be aware when you use this full screen missed call screen it will NOT display when your Q is locked, once you unlock the Q it comes on. (that is why i stopped using it)
Old 05-18-2007, 03:56 PM   #8 (permalink)
right...and also make sure that its your FIRST plugin in the code...so it shows up correctly!
Old 05-18-2007, 04:07 PM   #9 (permalink)
Hitokiri's Avatar
Idont see any coordinates.
Is it possible to place the text elsewhere along with adjusting the font size...lol
Hitokiri is offline
Old 05-18-2007, 04:09 PM   #10 (permalink)
no need for coordinates its the full screen....
and you can change the font size whatever you want...play with it and try different things
