Old 10-27-2007, 12:09 AM   #1 (permalink)
jacobburke's Avatar
jacobburke is on a distinguished road
Send a message via AIM to jacobburke
Default Default Verizon Wireless Home Screen - Where is the XML file???
I have searched the forum and have not seen any information on where the XML file is located for the default Verizon Wireless home screen on the Q. I am looking to replicate some of the layout used in that particular screen and would like to use the code from the XML file to save time in getting this done.
If anyone can help out here, I would appreciate it.
Cheers!
jacobburke is offline
Old 10-27-2007, 12:15 AM   #2 (permalink)
Cheers!
really?
\application data\home
thats where ALL homescreens are stored
Old 10-27-2007, 12:21 AM   #3 (permalink)
jacobburke's Avatar
The XML file for that specific home screen is not in that folder. Only the Windows / MSN home screens are there.
Old 10-27-2007, 12:24 AM   #4 (permalink)
you dont see ones called:
full.home.xml (i think its this one)
nomru.home.xml
simple.home.xml
vzw.full.home.xml
Old 10-27-2007, 12:29 AM   #5 (permalink)
jacobburke's Avatar
I do not have vzw.full.home.xml in that folder, yet the VZW Full Layout is listed in the Home Screens to use. The full.home.xml is one of the 'Windows' home screens. Any chance you can email me the XML file?
Old 10-27-2007, 12:32 AM   #6 (permalink)
i dont know what is considered the 'default verizon homescreen'
what does it look like?
and which of the ones i listed do you want?
did you have any of the others that i listed?
Old 10-27-2007, 12:41 AM   #7 (permalink)
jacobburke's Avatar
Here is a link to what the 'default' home screen is when you get the Q from Verizon. http://picasaweb.google.com/jacob.bu...86995488572610
The XML file that I need is: vzw.full.home.xml
I have the other files that you have on that list.
Thanks!
Old 10-27-2007, 12:42 AM   #8 (permalink)
Thanks!
ok PM me your email and ill send it over
Old 10-27-2007, 09:16 PM   #9 (permalink)
Some of the home screen files on a Verizon Q are in the \Windows folder -- look there.
-- Motorola Q, WM5, Verizonwireless, U.S.A. --
scottjb is offline
Old 10-29-2007, 10:45 AM   #10 (permalink)
Richard713's Avatar
Richard713 is on a distinguished road
in your file manager you can choose menu then options then uncheck hide sys files and also hide hidden files to view all files....
Richard713 is offline
The Following User Says Thank You to Richard713 For This Useful Post:
jacobburke (10-29-2007)
