Old 05-22-2008, 08:24 AM   #1 (permalink)
Tony Bag o Donuts's Avatar
Default Default background (not homescreen)
Has anyone ever changed the background of their start menu, etc?
If so, how do you go back to the default moto backgrounds?
The only way I get it to work is to restore from a backup.
Any ideas?
My photography website.
leave comments, etc.
Tony Bag o Donuts is offline
Old 05-22-2008, 08:39 AM   #2 (permalink)
yea i did.. but not yet after the Master Reset i did last week, uhm change back the registry to what it was ?
i know THR! and i believe Cindra (could have been somebody else) had some issues changing it back.
Old 05-22-2008, 08:54 PM   #3 (permalink)
cindra's Avatar
cindra is on a distinguished road
Yep, but it was more like accidentally deleting the background photo or changing the directory where stored that caused the problems. Required master resets for both of us, so I just leave the start menu background alone now!
You poke it, you own it.
cindra is offline
Old 05-22-2008, 09:09 PM   #4 (permalink)
thanks cindra... Tony your best bet is to find the default value i guess.
potQ.
Old 05-22-2008, 10:45 PM   #5 (permalink)
potQ.
I didn't change it this time, just was curious if I did, would a reset be needed.
Stupid how something so basic got missed by moto.
Old 05-23-2008, 01:13 PM   #6 (permalink)
cindra's Avatar
It was the weirdest thing because it made the Start Menu invisible. The menu itself was still intact, but it was like the font was transparent because you couldn't see the icons anymore. You could use the More and directional keys, and the center button would launch the apps!
Don't know if this additional info helps you or not. I believe THR! experienced the same thing.
cindra is offline
Old 05-23-2008, 01:17 PM   #7 (permalink)
OT nice avatar.
The Following User Says Thank You to Tony Bag o Donuts For This Useful Post:
cindra (05-23-2008)
