Old 11-24-2007, 11:37 AM   #61 (permalink)
halofive is on a distinguished road
when i download i get a .tgz file. Any suggestions?
halofive is offline
Old 11-24-2007, 11:51 AM   #62 (permalink)
thats a problem that some people are having (including myself)
a solution that i found that works is use your Q to download the cab file to install to the phone...for some reason the Q can pick it up as a cab whereas the PC wont
Old 11-24-2007, 04:23 PM   #63 (permalink)
xnight is on a distinguished road
Or as you download, when the save as window comes up just add.CAB to the name and it works too
xnight is offline
Old 11-24-2007, 04:25 PM   #64 (permalink)
really?
i thought someone who tried that said it didnt work...
i havent tested so i dont know for sure...but that would work out much better if it did!
Old 11-24-2007, 04:27 PM   #65 (permalink)
It just worked for me
xnight is offline
Old 11-24-2007, 04:32 PM   #66 (permalink)
hmmm good to know!
