Old 09-10-2007, 10:18 PM   #1 (permalink)
pinhead is on a distinguished road
Default Custom home screen request
Was wondering if anyone had time to create a home screen for me i will link the logo that i want and would appreciate if anyone had time to create this for me.
http://www.stormbowling.com/products...asp?ballid=232
would like the bowling ball with special agent logo and maybe if u could work in the storm logo as well.
thanks in advance
pinhead is offline
Old 09-11-2007, 08:23 AM   #2 (permalink)
welcome.... did this with little effort:
click here to download
oops.. forgot about the Storm logo, maybe that should be "water marked" in the background ?
pinhead (09-11-2007)
Old 09-11-2007, 01:09 PM   #3 (permalink)
thanks in advance
"Right Click" and "Save As"
I attempted to create a scheme with a set of Dark purple Soft Keys, but MS will only allow certain colors. My recommendation is that you look about the site for the black soft key .cab file and utilize that for a better layout.
Der Alta is offline
Old 09-11-2007, 01:54 PM   #4 (permalink)
Originally Posted by Der Alta View Post
*SNIP*
that is the difference between no effort, and effort :} will be added....
Old 09-11-2007, 01:55 PM   #5 (permalink)
very interesting you put the icon plugin at the bottom....a nice new look
good work
Old 09-11-2007, 02:00 PM   #6 (permalink)
took me a second... looks neat with the icon bar at the bottom, you're just not used to seeing it there :}
i should put mine in the homescreen collection.. (far removed from yours whaahaha :}
Old 09-11-2007, 03:46 PM   #7 (permalink)
And if you'll notice, the purple and yellow text matches the ball. I think I still have to tweak the ball placement a bit more to the left, and make the white splash more transparent behind the ball.
Der Alta is offline
Old 09-11-2007, 04:46 PM   #8 (permalink)
you hairsplitter :}
Old 09-11-2007, 08:39 PM   #9 (permalink)
Thanks very much to both of you for the quick reply and welcome...i like them both just diffrent things from both i like the backround of the pins and also like that all the shortcuts are on the other one i guess i dont need the storm logo. Guess i like darker colors but im not gonna be to picky thanks again
pinhead is offline
Old 09-11-2007, 10:00 PM   #10 (permalink)
no problem... a combination of the 2 is possible, it's not about being picky.. like us you probaly look a lot at your screen so it might as well as you like it.
