UPDATE: I managed to get the Black Keys working through a program called "BlackSoftKeys", how appropriate. Anyways, since that was the main bitch I had and it's fixed now, I went through and started changing the colors I wanted. With highly unexpected results. I have 3 different screenshots and you'll notice, they're extremely F'ed up.
I'll just go down the list on this one.
The IconBar is great, lovin it. However, I downloaded the Orange dll file but I haven't found 1 shred of code pertaining to how to use it despite there being a billion websites hosting HomeScreens. I downloaded a few and examined their codes but I can't find out how to do it for the life of me. I want to put the date and time up in the upper lefthand corner on the IconBar. Any suggestions would be appreciated.
The MRU is confusing me as well, it's hard to tell due to the dark background but whenever ANYTHING is selected on this bar the entire background is black, not just the selected icon. Making it impossible to tell which icon you have selected, again, any suggestions would be appreciated.
I would like to make the Tasks bar (Oxios), the Profile bar, and the Calendar appear in bold, haven't figured that one out either. I'm proud of myself that I managed to get them in white though.
However, the MessageCount bar refuses to show up in white. I've put the code in just about every place I can think of inside the plugin call but to no avail.
This one is pretty self explanatory. Obviously, I would like to see what other options I have on the screen but the unselected options, from what I can tell, have no color code.
This one has been plaguing me since I started this endevour. This is the screen where you would normally see the option to change the theme, default background, color scheme, and timeout duration for the Home Screen.
If anyone has any suggestions on how to just change the problem areas here, I'd greatly appreciate it. Oh, and here's the code.
<?xml version="1.0"?>
<home>
<author>B@eR</author>
<contacturl>http://www.datgroup.com/</contacturl>
<title lang="0x0409">Home Screen Beta 1.3</title>
<title lang="0x0809">Home Screen Beta 1.3</title>
<title lang="0x040c">Home Screen Beta 1.3</title>
<title lang="0x0407">Home Screen Beta 1.3</title>
<title lang="0x0410">Home Screen Beta 1.3</title>
<title lang="0x0816">Home Screen Beta 1.3</title>
<title lang="0x0C0A">Home Screen Beta 1.3</title>
<version>1.3 Beta</version>
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="normal" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="transparent" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="1">
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT" fgcolor="COLOR_HOMEHIGHLIGHTTEXT"/>
</default>
<background bgimage="blueqbiohazard.jpg" valign="bottom" bgcolor="COLOR_TRAYGRADLEFT"/>
<scheme>
<color name="COLOR_WINDOW" value="#000000"/>
<color name="COLOR_STATIC" value="#000000"/>
<color name="COLOR_STATICTEXT" value="#990000"/>
<color name="COLOR_HIGHLIGHT" value="#990000"/>
<color name="COLOR_HIGHLIGHTTEXT" value="#FFFFFF"/>
<color name="COLOR_MENU" value="#000000"/>
<color name="COLOR_MENUTEXT" value="#990000"/>
<color name="COLOR_GRAYTEXT" value="#DBDBDB"/>
<color name="COLOR_GRADLEFT" value="#990000"/>
<color name="COLOR_GRADRIGHT" value="#FFFFFF"/>
<color name="COLOR_INTGRADLEFT" value="#FFFFFF"/>
<color name="COLOR_INTGRADRIGHT" value="#990000"/>
<color name="COLOR_TRAYGRADLEFT" value="#000000"/>
<color name="COLOR_TRAYGRADRIGHT" value="#000000"/>
<color name="COLOR_HIGHGRADLEFT" value="#000000"/>
<color name="COLOR_HIGHGRADRIGHT" value="#000000"/>
<color name="COLOR_WINDOWFRAME" value="#BBBBBB"/>
<color name="COLOR_BTNFACE" value="#000000"/>
<!--Altered BTNTEXT to appear lime green for beta testing purposes-->
<color name="COLOR_BTNTEXT" value="#33FF66"/>
<color name="COLOR_SCROLLBAR" value="#999999"/>
<color name="COLOR_HOMETEXT" value="#FFFFFF"/>
<color name="COLOR_HOMERULE" value="#FFFFFF"/>
<color name="COLOR_HOMEHIGHLIGHT" value="#000000"/>
<color name="COLOR_HOMEHIGHLIGHTTEXT" value="#FFFFFF"/>
<color name="COLOR_ALERTWINDOW" value="#FFFFFF"/>
<color name="COLOR_ALERTTITLE" value="#000000"/>
<color name="COLOR_ALERTRULE" value="#000000"/>
</scheme>
<!-- Plug-Ins-->
<!-- Icon bar-->
<!-- MRU list: using small icons count:20-->
<!-- Carrier plugin -->
<!-- Profile plugin -->
<!-- Bluetooth plugin -->
<!-- Call Progress Plugin -->
<!-- Calendar Plugin -->
<!-- Extended (Beta) Message Count Plugin -->
<!--Iconbar-->
<plugin clsid="{837FC251-FE69-43ad-84E0-EBCEDEBA0884}" name="iconbar" height="27">
<iconbar fgcolor="COLOR_TRAYTEXT"/>
<background gradient="title" bgcolor="COLOR_TRAYGRADLEFT" b-border-color="COLOR_WINDOWFRAME" b-border-width="1"/>
</plugin>
<!--MRU-->
<plugin clsid="{79EFB752-CB70-446d-B317-499723482B3D}" name="startmru" height="30">
<mru y="1" icon-size="16" max-buttons="20" />
</plugin>
<!--Carrier-->
<plugin clsid="{E09043DF-510E-4841-B652-388316977A7A}" name="carrier" height="20" padding-left="-3">
<allowselection/>
<background b-border-width="1">
</background>
<label font-weight="bold" fgcolor="#FFFFFF" bgcolor="transparent" halign="left" x="110" y="-3" w="320" font-size="18">
<text><carrier/></text>
</label>
<clock>
<time font-weight="bold" fgcolor="#FFFFFF" font-size="16" valign="top" halign="right" y="-3" x="-18" w="320" />
<date font-weight="bold" fgcolor="#FFFFFF" font-size="16" valign="top" halign="left" mode="short" y="-3" x="5" w="320" />
</clock>
</plugin>
<!--Profile-->
<plugin clsid="{95976968-45D5-40c9-9779-2B859B1C2FEC}" name="profile" height="27">
<format state="selected" font-weight="bold" fgcolor="#FFFFFF" bgcolor="COLOR_HOMEHIGHLIGHT"/>
</background>
<label>
<format state="unselected" fgcolor="#FFFFFF" bgcolor="transparent"/>
<text lang="0x0409">Profile: <profile/></text>
<text lang="0x0809">Profile: <profile/></text>
<text lang="0x040c">Profil: <profile/></text>
<text lang="0x0407">Profil: <profile/></text>
<text lang="0x0410">Profilo: <profile/></text>
<text lang="0x0816">Perfil: <profile/></text>
<text lang="0x0C0A">Perfil: <profile/></text>
</label>
</plugin>
<!-- Bluetooth Plugin -->
<plugin clsid="{df648b7e-7645-419d-ba0b-503acea3edfb}" height="28">
</plugin>
<!--Call Progress-->
<plugin clsid="{37391041-C324-4725-BEE1-3232ED3539CA}" name="callprog" height="50">
<background>
<format state="selected" font-wight="bold" fgcolor="#FFFFFF" bgcolor="COLOR_HOMEHIGHLIGHT"/>
</background>
<format state="nocall" visible="false"/>
<label>
<text lang="0x0409">Call in progress:</text>
<text lang="0x0C0A">Llamada en curso:</text>
<text lang="0x040c">Appel en cours:</text>
<text lang="0x0410">Chiamata in corso:</text>
<text lang="0x0816">Chamada em curso:</text>
<text lang="0x0416">Chamada em andamento:</text>
<text lang="0x0809">Call in progress:</text>
<text lang="0x0413">Actieve oproep:</text>
<text lang="0x041b">Prebieha hovor:</text>
<text lang="0x0415">Trwa Wywolywanie:</text>
<text lang="0x0424">Klic poteka:</text>
<text lang="0x081a">Poziv u toku:</text>
</label>
<label y="23">
<text><progress/></text>
</label>
</plugin>
<!--Oxios Tasks-->
<plugin clsid="{0FD763F8-2BBE-42A1-94A8-A75A3758049E}" name="OxiosTasks" height="27">
<background>
<format state="selected" font-weight="bold" bgcolor="COLOR_HOMEHIGHLIGHT"/>
</background>
<format state="noevent" visible="false"/>
<label h="22" padding-right="14">
<text><subject/></text>
</label>
<priority x="-12" y="3"/>
</plugin>
<!--Calendar-->
<plugin clsid="{865A354A-4A96-4687-B001-C155DC0DBE76}" name="calendar" height="50">
<background>
</background>
<label h="22">
<text>
<subject/>
</text>
</label>
<label h="22" y="23">
<text>
<time/>
<location/>
</text>
</label>
</plugin>
<!--Message Count-->
<plugin clsid="{62E5C279-1E55-4bbb-95DA-D576093C23BE}" name="MessageCount" height="20">
<background>
<format state="selected" font-weight="bold" bgcolor="#000000"/>
<format state="unselected" font-weight="normal" fgcolor="COLOR_HOMETEXT"/>
</background>
<label>
<text lang="0x0409">Text Messages <unreadMsgs name="SMS"/></text>
<text lang="0x0C0A">Mensajes Del Texto <unreadMsgs name="SMS"/></text>
</label>
<label>
<text lang="0x0409" >Email <unreadMsgs name="ActiveSync"/></text>
<text lang="0x0C0A">Email <unreadMsgs name="ActiveSync"/></text>
</label>
<label>
<text lang="0x0409" >MMS <unreadMsgs name="MMS" /></text>
<text lang="0x0C0A">MMS <unreadMsgs name="MMS" /></text>
</label>
<label>
<text lang="0x0409">Voicemail <unreadVMail hidezero="true"/></text>
<text lang="0x0407">bbb <unreadVMail hidezero="true"/></text>
</label>
</plugin>
<plugin clsid="{856CB5C4-5B27-4b64-8FB9-7E3E4987E0D1}" height="25" autoheight="false">
</plugin>
<plugin clsid="{52E26FD7-2A56-4e2a-988B-2B90A96B90EF}" height="25" autoheight="false">
</plugin>
<plugin clsid="{1CC2E12E-B863-4603-9B5F-CA754B2BDDC6}" height="25" autoheight="false">
</plugin>
<plugin clsid="{6B9D9399-0F93-4ba1-9DC7-483FE4877E6D}" height="25" autoheight="false">
</plugin>
<plugin clsid="{B9E6C503-F261-4373-A88B-0B7ACF6BC347}" height="25" autoheight="false">
</plugin>
<plugin clsid="{30DF3430-0266-11cf-BAA6-00AA003E0EED}" height="25" autoheight="false">
</plugin>
</home>
If anyone knows the the hell those last 6 plugins are, please let me know. I'm with Verizon if it matters. Thanks in advance!
