Old 05-16-2007, 05:00 PM   #41 (permalink)
Prosper's Avatar
Originally Posted by baer3328 View Post
I'm new to this (although I'm learning very quickly) so try not to laugh too hard at my coding. It's a modified version of a preinstalled theme.
Why did you post your xml file .. ? I thought the registry color scheme thing gave you an error .. ? I'll need the files you modified to get the .cab file to have a look at that
Prosper is offline
Old 05-16-2007, 05:04 PM   #42 (permalink)
baer3328 is on a distinguished road
Send a message via AIM to baer3328
This stuff?
Necessity is the mother of invention
baer3328 is offline
Old 05-16-2007, 05:08 PM   #43 (permalink)
Prosper's Avatar
This stuff?
Right
You missed a #-character in line 12 in the postinstall.xml.
<parm name="COLOR_TITLEFLATCENTER" value="2C2CEE" datatype="integer" translation="install" />
It should be #2C2CEE
That's the only thing I saw when looking over it the first time...
Hope this helps you get it work
Prosper is offline
Old 05-16-2007, 05:10 PM   #44 (permalink)
Right
I actually missed two of them. Corrected but still unsuccessful
baer3328 is offline
Old 05-16-2007, 05:15 PM   #45 (permalink)
Prosper's Avatar
Hmm.. the 2 files you posted are correct.. (Edit: After editing the two missing character, of course...). I guess the error is located in the install.inf file. Would you mind posting it, so I can have a look .. ?
Prosper is offline
Old 05-16-2007, 05:17 PM   #46 (permalink)
Hmm.. the 2 files you posted are correct.. I guess the error is located in the install.inf file. Would you mind posting it, so I can have a look .. ?
Is it possible that black is restricted?
File Type: zip install.zip (375 Bytes, 2 views)
baer3328 is offline
Old 05-16-2007, 05:21 PM   #47 (permalink)
Prosper's Avatar
Restricted ? No, I don't think so. Otherwise the color scheme I provide on my page wouldn't work. But it does. But I can't find the damn error ...
Edit:
You inserted hexadecimal codes into the postinstall.xml. You will need to insert decimal codes. Read the first part of Step 4 carefully again. Maybe this causes the error...
Prosper is offline
Old 05-16-2007, 05:29 PM   #48 (permalink)
Edit:
No, I flipped the characters around like the tutorial said. I double checked. Regardless, it would've come out with a color. Just not the color I wanted.
Nevermind, I think I know what you're saying. The German page was giving me an error. I found an english one. Do I still need to input the # characted in front of it?
baer3328 is offline
Old 05-16-2007, 05:34 PM   #49 (permalink)
OK. Got the damn thing to install but it's giving me the great error of "The layout you have selected cannot be..." error. Suggestions?
baer3328 is offline
Old 05-16-2007, 05:40 PM   #50 (permalink)
Prosper's Avatar
Ok, I'll try to explain what you have to do exactly.
First, you take a color. Let's take the red you wanted the text to be.
1. The code for this red color is #EE2C2C.
2. Swap the first two and the last two digits: #2C2CEE.
3. Goto the German page I linked to in the tutorial and enter the swapped code (2C2CEE) into the field saying "Wert". Press hex -> dez.
4. The outcoming is 2895086.
5. This code has to be entered into the postinstall.xml (in your case into the value of COLOR_SOFTKEYFLATCENTER).
Hope this clarifies the way.
Prosper is offline
