Old 05-16-2007, 03:52 PM   #31 (permalink)
yea you can i have done it
Old 05-16-2007, 03:59 PM   #32 (permalink)
baer3328 is on a distinguished road
Send a message via AIM to baer3328
Not this way
baer3328 is offline
Old 05-16-2007, 04:10 PM   #33 (permalink)
leave it grey at the top and then save it...dont do anything else...go in to the xml file and look at the color and change it to black #000000 and load it back in to the the editor and your set
edit: you will that btnface doesnt show up as the color for the softkeys...but color_traygradleft does....
Old 05-16-2007, 04:17 PM   #34 (permalink)
Originally Posted by Prosper View Post
You may want to have a look at this here for changing the softkeys' colors ;)
Tried this and it didn't work. Got it to work up until install and it read install unsuccessful
baer3328 is offline
Old 05-16-2007, 04:47 PM   #35 (permalink)
@baer3328
try using this...i use this to get started on homescreens....then bring it to xml and modify it
http://madbeetle.com/HomeScreenBuilder.html
It won't let me create the .cab file. I altered the XML document to display 000000 in TRAYGRADLEFT and transferred over and it didn't change it to black. WHAT THE HELL IS WRONG WITH MY Q? lol
I'm working with the latest software and multiple registry hacks, I don't know if that makes a difference
baer3328 is offline
Old 05-16-2007, 04:49 PM   #36 (permalink)
dont make it a cab file...
copy the xml file and the jpg image to the \application data\home folder
much easier...ive had trouble with the cab portion...i just dont use it
i use the program to set up my colors and alignments and then mess with the xml file to get it correct
Old 05-16-2007, 04:51 PM   #37 (permalink)
I did that after attempting to do the .cab file. It still doesn't turn it black.
baer3328 is offline
Old 05-16-2007, 04:55 PM   #38 (permalink)
lol....have you tried to make another homescreen as a test?
Old 05-16-2007, 04:55 PM   #39 (permalink)
Prosper's Avatar
There must be an error in your source code. You may wanna post your files here and I'll have a look.
Prosper is offline
Old 05-16-2007, 04:58 PM   #40 (permalink)
I'm new to this (although I'm learning very quickly) so try not to laugh too hard at my coding. It's a modified version of a preinstalled theme.
Necessity is the mother of invention
baer3328 is offline
