Old 05-16-2007, 03:26 PM   #21 (permalink)
ah i see...
any thoughts on why his isnt working...?
Old 05-16-2007, 03:28 PM   #22 (permalink)
baer3328 is on a distinguished road
Send a message via AIM to baer3328
edit:
wait a sec...try this...
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="normal" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="transparent" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="1">
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT">
</default>
Didn't work. Also having issues with the clock overlaying the date but that's something I'll have to work on later. The bottom line is that the code that should produce black keys isn't producing black keys.
<color name="COLOR_BTNFACE" value="#000000"/>
You would think black would be supported.
baer3328 is offline
Old 05-16-2007, 03:32 PM   #23 (permalink)
do other colors work?
Old 05-16-2007, 03:33 PM   #24 (permalink)
From what I can tell, yes. I haven't quite figured out where they all go but I have modified the majority of the colors.
baer3328 is offline
Old 05-16-2007, 03:34 PM   #25 (permalink)
Prosper's Avatar
Solution: registry hacks.
Or: using the black scheme you can get from my page on the Plugins page.
Prosper is offline
Old 05-16-2007, 03:37 PM   #26 (permalink)
i have that plugin installed on my Q....but in theory you shouldnt need that to customize the softkeys....
Old 05-16-2007, 03:41 PM   #27 (permalink)
Prosper's Avatar
Just if you want black or custom color softkeys, like described in the link I provided. ;-)
Prosper is offline
Old 05-16-2007, 03:45 PM   #28 (permalink)
@baer3328
try using this...i use this to get started on homescreens....then bring it to xml and modify it
http://madbeetle.com/HomeScreenBuilder.html
Old 05-16-2007, 03:46 PM   #29 (permalink)
In theory...
That's exactly why I'm confused
baer3328 is offline
Old 05-16-2007, 03:51 PM   #30 (permalink)
@baer3328
You can't use black with this program either.
baer3328 is offline
