Old 05-16-2007, 02:53 PM   #11 (permalink)
why do you have this code?
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="bold" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="COLOR_HOMETEXT" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="1">
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT" fgcolor="COLOR_HOMEHIGHLIGHTTEXT"/>
</default>
what does that do for you?
Old 05-16-2007, 03:03 PM   #12 (permalink)
baer3328 is on a distinguished road
Send a message via AIM to baer3328
</default>
It's the default code for one of the themes already installed on the Q. It all refers to the color scheme doesn't it?
baer3328 is offline
Old 05-16-2007, 03:09 PM   #13 (permalink)
edit:
wait a sec...try this...
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="normal" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="transparent" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="1">
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT">
</default>
Old 05-16-2007, 03:12 PM   #14 (permalink)
yea...i think its referencing that rather than your scheme..
this xml code shouldnt refernce another homescreen...remove it and see what happens
Pardon my stupidity, by I'm not seeing where it's referencing another scheme. This is the 'defaults' code that I saw in every tutorial about making your own theme so I figured I had to put it in there. Without it, I'm pretty sure it won't display due to the fact that it contains the resolution for the screen. If I could, I'd delete the reference to the other scheme, but I'm not seeing it.
baer3328 is offline
Old 05-16-2007, 03:13 PM   #15 (permalink)
yea i miss understood that you meant...look at my post above...
Old 05-16-2007, 03:17 PM   #16 (permalink)
Prosper's Avatar
</default>
This got nothing to do with the color scheme !
This part (the <default> tag) defines standard xml values, which will be taken in every other tag if not specified another way.
For example, if you set the font-size to 20 in the default tag, the font will be size 20 in every other plugin if not set different in the specific plugin.
Hope it's understandable.
Prosper is offline
Old 05-16-2007, 03:19 PM   #17 (permalink)
i realized that after i posted it....
ive been trying to compare it to my other screens i have with the start button color changed and they seem pretty similar in the scheme area....
Old 05-16-2007, 03:21 PM   #18 (permalink)
Prosper's Avatar
You may want to have a look at this here for changing the softkeys' colors ;)
Prosper is offline
Old 05-16-2007, 03:23 PM   #19 (permalink)
wow thats alot of steps...lol
can you use this COLOR_SOFTKEYBTNFACE
with out all the steps?
i have never seen that before when doing the homescreens....
Old 05-16-2007, 03:25 PM   #20 (permalink)
Prosper's Avatar
Sure you can. But it won't work in the xml file. You will need to work with the registry hacks.
Prosper is offline
