Originally Posted by Der Alta I've taken a quick look at the coding of a few of your screens, and I can't figure out why you're using the Orange plugin on some of them. IN fact, I didn't see any Orange coding in the XML files.
Are you certain that you need the Orange plugin on the ones you've posted?
I'm just checking, as I think that some people avoid downloading ones that require it, and it appears your screens may be available to a wider range of users. |
DA is right. Some of the HS's u posted don't require Orange in them. U might want to go back & c which ones don't use it & edit your posts. Good catch DA
It doesn't look like Gators, Indiana, Tinkerbell, or Kitty use it by just looking at the HS snapshot. (unless u have something hidden until it is selected.)
