Old 01-03-2007, 01:27 PM   #1 (permalink)
johnpr63 is on a distinguished road
Default Copy XML Problem
Everytime I try and copy my custom XML I get an "access denied" message. I can copy other files types just fine - only XML have a problem. I'm running ActiveSync 4.2 and IE7 if that helps at all.
Any thoughts?
Thanks-
johnpr63 is offline
Old 01-03-2007, 02:31 PM   #2 (permalink)
VTDr0p0ut's Avatar
Where are you trying to copy them to? Whenever I get those msgs, I typically just copy them over to My Doc's, then use the file browser to move them to the appropriate location.
VTDr0p0ut is offline
Old 01-03-2007, 02:39 PM   #3 (permalink)
Thanks VT but that didn't work either. I even tried changing the extension to something other than XML but the Copy & Convert "wizard" seems to recognize it is an XML and doesn't know what to do with the file.
johnpr63 is offline
Old 01-03-2007, 04:13 PM   #4 (permalink)
VTDr0p0ut's Avatar
Option 2: Zip it, then use Total Commander (or your favorite utility) to unzip it. Betchya ActiveSync will leave it alone then.
