If you've installed Orange (check n99hockey's homepage for it) all you need to do is edit your current XML homescreen (Make sure to keep a backup of the original) and add this section in place of the current Fizz Weather.
<!-- Squished Weather -->
<plugin width="320" handlekeys="CHILD" clsid="{A2536C57-6AC2-4c31-9542-B144B0E9D077}">
<shortcut width="120">
<!-- Spacer plugin-->
<plugin height="24" file="sysplug.dll" clsid="{E09043DF-510E-4841-B652-388316977A7A}"/>
</shortcut>
<shortcut width="200">
<plugin clsid="{30DF3430-2005-0509-BAA6-00AA003E0EED}" name="WeatherPlugin" >
<general sepline="false"/>
</plugin>
</shortcut>
</plugin>
The unfortunate side effect that I haven't conquered (yet) is that the right plugin is unselectable. With the Blank (or "Spacer") plugin on the left, Fizz weather is inaccesible. You have to access it via the Start menu.
Now, to really smooth this screen out, you'd have to move Bob to the right side of the screen, rebuild everything on the left, and then Fizz Weather would align in the proper spot.
