Old 02-16-2008, 01:48 PM   #1 (permalink)
peppersghost's Avatar
peppersghost is on a distinguished road
Default Color Theme
How do I change my color theme so most is black? I am using edgy right now which is grey and all the other ones I don't really like.
peppersghost is offline
Old 02-16-2008, 02:58 PM   #2 (permalink)
you mean your soft keys? (start button and right menu button?)
Old 02-16-2008, 03:20 PM   #3 (permalink)
Yeah that, but like I want the theme to be black also if that's possible.
Old 02-16-2008, 03:47 PM   #4 (permalink)
like the incall screens?
those you have to create images for
Old 02-16-2008, 03:58 PM   #5 (permalink)
Is there a thread about how I would go about doing this?
Old 02-16-2008, 04:21 PM   #6 (permalink)
i would search for the 'ultimate customization thread'
that should help you out as well as point you to some other links that could give you some direction
peppersghost (02-16-2008)
Old 02-16-2008, 04:24 PM   #7 (permalink)
Thanks a lot.
Old 02-16-2008, 04:40 PM   #8 (permalink)
Thanks a lot.
yes sir
Old 02-16-2008, 04:40 PM   #9 (permalink)
mike250rs's Avatar
can also install the blackSoftKeys.cab
mike250rs is offline
The Following User Says Thank You to mike250rs For This Useful Post:
