Old 10-11-2007, 08:45 AM   #31 (permalink)
Originally Posted by kc2607 View Post
Hi RB,
Thanks for your quick help. I am able to download and add to my collection.
no problemo... once you got them i might go ahead and delete them, still haven't found out what the limit is here for the total size of attached files, guessing there must be one :}
Old 10-11-2007, 09:10 AM   #32 (permalink)
kc2607 is on a distinguished road
Smile Sure
Sure RB, you can do that. I hope others are able to access directly from their respective links. We need to keep storage space here as I guess I might be in this situation in future sometime again. Will post msg then as needed.
Cheers!
kc2607 is offline
Old 10-11-2007, 09:18 AM   #33 (permalink)
Cheers!
i leave them for a little while... i want to look into how much we can actually "store" here as a user, or if it is a endless well -which i doubt- :}
Old 10-11-2007, 02:40 PM   #34 (permalink)
There is an attachment limit, but being staff, you should likely have more. In all honesty, noone else had an issue downloading them. I suspect it was on the users end that prevented him from downloading them.
One of these days, I'll get around to building a web page to showcase all the screens I've done.
And because someone asked very nice and proper for them, I've added a V3 and V4 of the Coke screens.
V3:
"Right Click" and "Save As"
V4:
Der Alta is offline
mrjingles (10-11-2007)
Old 10-11-2007, 02:56 PM   #35 (permalink)
very well possible..
*SNIP*
yes you are correct.. it was an access issue on his side.
Old 10-11-2007, 03:19 PM   #36 (permalink)
mrjingles's Avatar
mrjingles is on a distinguished road
V3:
V4:
Thanks Der Alta!! I'm the one who requested them and they look wonderful!!
mrjingles is offline
Old 10-11-2007, 03:58 PM   #37 (permalink)
No problem, you're very welcome.
Der Alta is offline
Old 10-11-2007, 04:01 PM   #38 (permalink)
use the THANKS! button to show utter gratitude...
Old 10-11-2007, 04:12 PM   #39 (permalink)
He did, and it is appreciated.
Der Alta is offline
Old 10-11-2007, 04:23 PM   #40 (permalink)
ok, i see now. you really deserve it.. you do some awesome work. now one wonders what home screen do you use ?
