Old 08-20-2008, 06:57 AM   #1 (permalink)
ninjaap's Avatar
Default Clock Icon disappeared (sliding panels)
I've recently uninstalled Pocket Sports Center plugin for my sliding panels and now I have an annoying little red X at the top left corner where the small clock icon is supposed to be. I tried reinstalling PSC and I still have that X. So I'm thinking either the icon path was overwritten or the clock icon itself was overwritten or deleted.
Looking at reg path:
HKLM\Software\Microsoft\CHome\CClock\ICONPATHS
I see:
Am I correct to assume this is the icon path for the small clock? If so, could someone please tell me the correct path?
ninjaap is offline
Old 08-20-2008, 09:40 AM   #2 (permalink)
fr4nk1yn is on a distinguished road
My 9c has "2051;2051" there.
Strange if that doesn't work try "2151;2151" which is what is says now.
I wrote it down so it did say 2051.
fr4nk1yn is offline
The Following User Says Thank You to fr4nk1yn For This Useful Post:
ninjaap (08-20-2008)
Old 08-20-2008, 03:08 PM   #3 (permalink)
ninjaap's Avatar
Default Mini weather and pocket sports center
Thank you very much for taking the time to look that up for me. I have opted instead to do a master clear, because besides the X, the phone keeps wanting to run an exe file for mini weather (which I removed) and I keep getting an error. Apparently it wasn't a very clean removal by windows. Anywho, I'm back to normal now with a fresh new phone. Off to try new apps so I can mess with my registry again . The reset button is probably the best app on the phone IMHO. Bails me out everytime, allowing me to make mistakes so I can learn from them. Thanks again.
WARNING: NRG mini weather and pocket sports center 6.1 plugin are not compatible. You have to run one or the other. PSC will give you that annoying X when removed from your phone. Both apps changes the registry when installed and does not completely change it back when removed.
EDIT: I take it back. If you disable the Ctestui panel, they work fine together. This panel contains the 5 day forecast, which you would have to give up. This will also solve the auto reboot problem when you're trying to shutdown your phone. Although, it's not actually rebooting, the phone is crashing and windows restarts automatically to restore your settings.
ninjaap is offline
Old 08-20-2008, 03:39 PM   #4 (permalink)
Easy fix.
I have all my apps in a folder with cab install. Just synce then drag and drop to install them.
My CHome config is the only time consuming part.
Althought I have just started changing default screens.
You never know how an app will behave until you try it ):
fr4nk1yn is offline
