Old 12-20-2007, 02:34 PM   #1 (permalink)
Valkyr47 is on a distinguished road
Default Cleaning out themes/homescreens
i just purchased facade, and before i use it to make a brand new theme and layout, i noticed i have a ton of random ones and ones facade has made (sometimes i get this error message about theme being read only, so it makes a duplicate but adds copy to the end or something) and i want to clean them out, just to serve my OCD'ish needs
when browsing to the application data/home folder through my laptop, can i just clear out the entire folder completely? will this damage facade in any way? im talking about all the xml and theme files in that folder
Valkyr47 is offline
Old 12-20-2007, 02:40 PM   #2 (permalink)
no you dont need those files if you dont want them
they are just for homescreens added by facade
Old 12-20-2007, 02:49 PM   #3 (permalink)
first off, thanks for recommending facade, so far it looks like it was worth the money.
Second, so i can clean out the entire folder and still be able to make a theme? awesome, i just have ocd when it comes to files sitting around on the phone
Lastly, i asked you a bit about this on the Q9m board, but if i find a theme i like, is it easy to remove the windows mobile iconbar at the top? the one that by default has the battery state, wireless strength etc? i just see no point in having that when most of those stats are in the facade bar... i opened the theme in notepad and found the plugin listed, is it as simple as removing that line of text?
thanks for all of your help!
Valkyr47 is offline
Old 12-20-2007, 03:01 PM   #4 (permalink)
see i told you...haha totally worth it
you can remove all of them...but then you wont have any screens
you have to leave the xml and jpg images of the screens you want to keep
yes just edit the xml file in note pad on your PC and remove the icon plugin and then put it back on the Q
thanks for all of your help![/quote]
