Old 05-17-2007, 01:19 PM   #1 (permalink)
GEPTRONIXDJS's Avatar
GEPTRONIXDJS is on a distinguished road
Need Help Changing The Home Screen
i am looking at finding a way to remove the (home service) label on the home screen and change it to personalize it to my liking. anybody have any idea how to do this please let me know.
thanks
GEPTRONIXDJS is offline
Old 05-17-2007, 01:38 PM   #2 (permalink)
i believe its the carrier plugin...that displays home service...
Old 05-17-2007, 01:41 PM   #3 (permalink)
call me stupid but in this case i would have to contact verizon or whoever your phone service is thru to see if they have the plugin.
Old 05-17-2007, 01:41 PM   #4 (permalink)
try using this for the text you want
<label>
<!-- NOTE If you want your name above the time replace "XP Mobile" in the next line with your name -->f(clean);
<text font-size="18" fgcolor="#ffffff" halign="left" y="66">XP Mobile</text>
</label>
change the text color and size, etc. to your liking...
Old 05-17-2007, 01:42 PM   #5 (permalink)
<label>
</label>
ok call me stupid again but where do i go to get into this information
Old 05-17-2007, 01:43 PM   #6 (permalink)
no just edit the xml file and erase it....
Old 05-17-2007, 01:44 PM   #7 (permalink)
sorry to keep bugging you but how do i get into the xml file to change it
sorry
Old 05-17-2007, 01:48 PM   #8 (permalink)
on the Q its in the \application data\home folder
copy it to your desktop..edit it in notepad and then move it back to the Q in that same folder
Old 05-17-2007, 01:54 PM   #9 (permalink)
YOU THE MAN
THANKS
Old 05-17-2007, 01:58 PM   #10 (permalink)
no problem!!!!
