Old 09-21-2007, 08:50 AM   #1 (permalink)
inbarit1984 is on a distinguished road
Default change a web site build in a homescreen
hello,
does any one knows how 2 change the website address from my provider's homescreen that i use?
i love the homescreen but i hate the fact that the provider's address in there.
please help!
thanks,
Amber
inbarit1984 is offline
Old 09-21-2007, 08:52 AM   #2 (permalink)
Originally Posted by inbarit1984 View Post
hello,
please help!
thanks,
Amber
you can edit the xml file which can be found in the
\application data\home folder
or if you want...zip the xml file in that folder of the screen you are using
then post it here and i can change it up for you
Old 09-21-2007, 08:53 AM   #3 (permalink)
--moved to homescreen forum--
