Old 09-12-2007, 07:21 PM   #1 (permalink)
N7AS's Avatar
N7AS is on a distinguished road
Send a message via MSN to N7AS
Default Carrier on Iconbar?
Is there a way to put the Carrier on the Iconbar using Orange.dll?
I've tried modifing the 'Time on Iconbar", but can't seem to get it to work. There must be some error, as the homescreen will not appear in the selection list.
Has anyone tried to do this?
Grant
SprintQ.net - N7AS.com
Motorola Q
Sprint
N7AS is offline
Old 09-12-2007, 07:31 PM   #2 (permalink)
i succeeded putting the clock on the icon bar but not anything else... did i already given you my homescreen xml so you can look at it ?
Old 09-12-2007, 07:55 PM   #3 (permalink)
Yes, you can do it pretty easily. Much the same way you put the clock in there. I'd do a quick one for you, but I am headed to bed shortly, 4am comes early.
If I get a chance tomorrow, I'll put one together and upload it.
Der Alta is offline
N7AS (09-13-2007)
Old 09-12-2007, 08:33 PM   #4 (permalink)
seriously ? you succeeded doing so.. i tried putting i believe it was the profile but didn't spent too much/enough time i guess :}
Old 09-12-2007, 10:18 PM   #5 (permalink)
N7AS's Avatar
I don't think I have your xml. I would be interested in seeing it.
I tried recoding the xml for the clock on the Iconbar, but it would not load. I think it would be logical to have the Carrier on the Iconbar. Besides, I like my clock to be larger than the size than go there.
Grant
Motorola Q
Sprint
N7AS is offline
Old 09-12-2007, 10:24 PM   #6 (permalink)
N7AS's Avatar
Thanks. I will be looking for it. I tried to do it like the clock, but failed. I wish there was some kind of emulator that would read all plugins (orange.dll, HomeScreenNotificationPlugin.dll and such) so I could review it on the PC first. Something without having to install an SDK.
Grant
Motorola Q
Sprint
N7AS is offline
Old 09-13-2007, 08:35 AM   #7 (permalink)
you can get the .xml here, it's the Mesh.home.xml secondly did you check if Orange is installed ? you should see it in your Remove Programs, it's called JRulez OHSP.
N7AS (09-13-2007)
Old 09-13-2007, 08:37 AM   #8 (permalink)
thanks dude... that would allow for some extra unused real-estate in case the clock is elsewhere.
Old 09-13-2007, 01:11 PM   #9 (permalink)
N7AS's Avatar
Orange is installed and working on other homescreens including some I created.
Grant
Motorola Q
Sprint
N7AS is offline
Old 09-13-2007, 02:32 PM   #10 (permalink)
I'm really amazed that you didn't figure this one out yet.
Did this up real quick. Used the Carrier text from my Ironman page, and a home page that had orange already built in. A quick combo and I get this
The xml code is in this zip file Download (its only 1k)
Hope this helps.
Der Alta is offline
N7AS (09-13-2007)
