Originally Posted by Der Alta Just realized that I miss typed the image path.
As a hint, open the file on your PC in an xml editor. It'll tell you where the file is corrupt. |
I figured that I put in a / in place of the dot, I would see the image.
I opened my xml in IE on the PC and got: End tag 'home' does not match the start tag 'plugin'.
The end </home> was there, so I couldn't figure why. Anyway, I modified another one of my homescreens with your code with a color mod and shifted the carrier a few pixels to the left and it works fine.
