Originally Posted by Csquared Inside \Application Data\Home you should have a folder called CarbonFiber Tabs. Inside that folder will be all the .jpg's for the homescreen. The XML file will not be in the same folder it will be in \Application data\Home. You then should set your Home screen layout to Carbon Fider Tabs and everything else to default. Also inside Fizz you should have your homescreen set to Large 5 day. Do you have Facade? |
YAHTZEE! Thanks for the advice. Between you and the n99hockey, I figured it out. I had copied the carbonfiberfizz folder into application data/home, but had not copied the contents of that folder into the application data/home as individual files. Does that make sense? According to my understanding of what you write above, does just the .xml file need to be located in application data/home?
<edited to add: I don't have facade, but I don't believe this download requires it. I'm thinking about getting it though, seems like a useful app.>
