Originally Posted by NJKiko I'm having the same problem as you. I copied the xml file along with the entire CarbonFiberTabs directory to "Application Data\Home\". However, if you look at the xml file, it points to the wrong location for the tab images. The xml says they should be in "Application Data\Home\CarbonFiberTabs\*.jpg" when in all actuality they are located in "Application Data\Home\CarbonFiberTabs\CarbonFiberTabs\*.jpg". I tried updating the xml code to point to the right directory, but that didn't work. Nor did leaving the xml code alone and putting the tab images into the directory that the xml lists.
Any thoughts? |
there should just be a folder inside the \application data\home folder called CarbonFiberTabs
all the jpegs should be in there and the xml file in the \application data\home folder
and thats it
also make sure you have facade (might not be so obvious by the name that you need this) and fizz weather installed
EDIT: also make sure that you have the background image in the homescreen settings set to default
ALSO...if you are using facade 1.3 the tabs will not work...there is a thread started about this...since the upgrade from 1.2 to 1.3 this part doesnt work and SBSH creators are looking in to this problem
i had to reinstall facade 1.2 to get it to work right again
