Old 10-02-2007, 10:24 PM   #11 (permalink)
Originally Posted by johnknight View Post
mmhmm... :scratches head: what does that mean???
was this regarding what i said ?.. the tabs used in many Facade screens are 6 images placed in a separate folder in the \Application Folder\Home\<often_the_homescreen_name> 3 for the unselected tabs, and 3 (yes you guessed it) for the selected tabs. hope this is what you were asking else i typed all this well, for nothing :}
Old 10-02-2007, 10:32 PM   #12 (permalink)
jknight4200's Avatar
jknight4200 is on a distinguished road
Send a message via AIM to jknight4200 Send a message via Yahoo to jknight4200
<hehehe> yep that's what I was asking. so i would be able to find them on the Q and change them??
J.K.
~ My Q Apps ~ Homescreens ~
jknight4200 is offline
Old 10-02-2007, 10:36 PM   #13 (permalink)
yep, they come with the home screen..
Old 10-02-2007, 11:38 PM   #14 (permalink)
hawkman610 is on a distinguished road
Thanks John, that looks good. Does it have a missed call indicator that will show up, or a different screen that pops up?
hawkman610 is offline
Old 10-02-2007, 11:56 PM   #15 (permalink)
No, just the phone icon w/ exclamation point. All I did was change the pic on an existing Facade homescreen, so it wasn't there to begin with.
J.K.
Old 10-03-2007, 12:00 AM   #16 (permalink)
to do 2 quotes
hit the + and the quote bubble then hit quote in the next post you want and bam 2 quotes
Ahh quote overload!! Now when I just want to reply & quote one post this is what happens! What to do?
J.K.
Old 10-03-2007, 09:36 AM   #17 (permalink)
if you already selected it and just want 1 quote instead of 2 then just hit the + sign and quote bubble again of the post you DONT want to quote
OR
you can just delete the text in the reply box
Old 10-03-2007, 09:37 AM   #18 (permalink)
somebody is having fun with quoting :}
Old 10-03-2007, 03:15 PM   #19 (permalink)
Click here to download. I have replaced my name with YOUR TEXT HERE - replace it in the xml with whatever you want. I cannot figure out how to change the color of the schedule/tasks/programs tabs. You could download some red softkeys if you'd like though (start/contacts bar). It is in the link in my signature in the Home Screens folder under red scheme.
Could you have labed YOUR TEXT HERE with somthing else? I can't find it.
I think I'm looking in the xml document, it looks like a bunch of html.
Old 10-03-2007, 03:37 PM   #20 (permalink)
I can later when I get home. If you transfer that .xml from the Q to your pc and open it with notepad you can edit it. Then save your changes and move it back to the Q replacing the existing file.
J.K.
