Originally Posted by crazykay It is simple dear! Install 3.1 use that HS under your HS settings, then use Chome Configurator to disable those 2 sliding panels and your done.. Just gotta make sure the right weather program is installed.. Matter of fact uninstall Mini Weather all together.. and yes you might have a blank screen but just reboot your phone and it will be back up |
Ok...That done it...Thank you so very much...
