Old 08-11-2008, 01:56 PM   #11 (permalink)
crazykay's Avatar
crazykay is on a distinguished road
Send a message via Yahoo to crazykay
Originally Posted by Idntknw View Post
Sorry to bump this up again...but...
I still haven't had any luck with this...
anyone else have any ideas?
Posted in 2 different forums and still no answer!! poor guy!! so you installed the .cab file from xda and then restarted (not master reset just plain old reboot) your phone and still no luck?? Where are you installing the .cab file.. Your storage card? If so - dont...and make sure you Install it on your device. If that doesnt work we can try something different for you. let me know.
I use Smartmonitor on most of my HS Creations. Thanks to docmac129 for letting me and most other creators use the meter bars and code he created
crazykay is online now
Old 08-11-2008, 02:01 PM   #12 (permalink)
Idntknw is on a distinguished road
Lol...yes...trying in two different forums...
Yes...I installed it to my device...nothing...just changed the system fonts...
I have even went into the registry...trying to find anything and found..
Fonts under the CHome...
It has listed 4 different strings...all say Segoe light...I have changed those to calibri...nothing...
So...I have no idea what else to do....
thanks for your compassion...lol
Idntknw is offline
Old 08-11-2008, 02:33 PM   #13 (permalink)
crazykay's Avatar
Have you tried it with one of the NRG Weather Sliding Panels Screens?? Like NRG Mini Weather 1.0
Also if you havent already.. try this calibri.cab file found here
Old 08-11-2008, 02:34 PM   #14 (permalink)
Yes...that is the only way to get the font to work on the home screen...but...
Didn't want the weather panels...
Idntknw is offline
Old 08-11-2008, 02:44 PM   #15 (permalink)
crazykay's Avatar
well ok then use the chome weather nrg 3.1 version and download chome configurator and use it to disable those two panels and u should have it without showing the weather panels!!
Old 08-11-2008, 02:45 PM   #16 (permalink)
well ok then use the chome weather nrg 3.1 version and download chome configurator and use it to disable those two panels and u should have it without showing the panels!!
Ok...I will give that a shot...
Thanks...
Idntknw is offline
Old 08-11-2008, 03:38 PM   #17 (permalink)
Well...I installed the weather thing...and I have the font now...but...even after I disabled the weather panels...there is still a little forecast thing next to the clock...so...
I give up...just uninstalled the weather thing and giving up!...lol
Thanks again for your help...
Idntknw is offline
Old 08-11-2008, 04:14 PM   #18 (permalink)
crazykay's Avatar
Thats because you installed Nrg MINI weather and are using that HS.. Install NRG Chome Weather 3.1 and then disable the two!! Mini weather will always put that next to your time but Chojme weather 3.1 will not
Old 08-11-2008, 04:21 PM   #19 (permalink)
Ok...I will give it another shot...
I will say it gave me a scare when I installed the weather thing...when I went to change my home screen back to sliding panels...it wouldnt change to it...it was a blank screen!...
Anyway...I uninstalled it and everything is back to normal...
But...I will try 3.1...
This is kinda crazy...looks like there would be a simpler way to do this?...
Thanks...
Idntknw is offline
Old 08-11-2008, 04:28 PM   #20 (permalink)
crazykay's Avatar
It is simple dear! Install 3.1 use that HS under your HS settings, then use Chome Configurator to disable those 2 sliding panels and your done.. Just gotta make sure the right weather program is installed.. Matter of fact uninstall Mini Weather all together.. and yes you might have a blank screen but just reboot your phone and it will be back up
