Im not sure I understood exactly what you mean, but I will just define the steps needed for get it to work
The xml is still named he same, but just updated. So obviously extract the files from the zip and place them into the home folder. Should be 3 files. The home screen, the missed calls and the xml file.
If you are already using the bleach homescreen, switch to another homescreen, then switch back. This should refresh the Q and show the correct HS
edit:
after re-reading your post, let me reiterate. Extract ALL 3 files and upload ALL 3 into your Q. The files have been reduced in size (due to the size restrictions on here) as well as the xml modified.
