Old 07-23-2007, 12:43 AM   #1 (permalink)
Roedub is on a distinguished road
Default Blacksoftkey.cab question
Ok so Im using the .cab with the large font layout. I have a pic for a background but it only takes up the bottom half of the screen. my pic is black but since it's only half screen the other half is turquoise. is there anyway to get rid of the turquiose and make it black?? that way it will match with the pic i'm using.
Roedub is offline
Old 07-23-2007, 09:29 AM   #2 (permalink)
your best bet would be to change the xml file of the homescreen that you are using so it will take up the whole screen...and this way you can set your background image in the homescreen manager to 'default' and it will take up the whole screen
Old 07-23-2007, 07:14 PM   #3 (permalink)
Thnx! I'll try that
Roedub is offline
Old 07-23-2007, 08:01 PM   #4 (permalink)
Thnx! I'll try that
ok...post back if you run into trouble
