Old 08-30-2008, 01:45 AM   #11 (permalink)
BigTK's Avatar
BigTK is on a distinguished road
See first post...I loaded some screen shots and could use a little help.
BigTK is offline
Old 08-30-2008, 07:30 AM   #12 (permalink)
crazykay's Avatar
crazykay is on a distinguished road
Send a message via Yahoo to crazykay
looks awesome!! I would test this for you but I don't have PhoneAlarm. what exactly is your problem? I might be able to help you just by looking at your xml if you want to PM it to me.
crazykay is offline
Old 08-30-2008, 08:18 AM   #13 (permalink)
Geekster's Avatar
I like where you are going with this.
Looking good, man!
I know between you and CK that any problems can be worked out.
Simple solutions to your problem are: A Master Reset or you may have to edit the binary information by encrypting the decimals of the dynamic part of the triothonic file..duh who doesnt know that? .... Make sure you dont overclock your multilomoter when you editing the binary files b/c it might reconfigure your harddrive and your q might blowup.
See? Simple solutions.
http://www.frappr.com/?a=constellati...d=137440517530
Geekster is offline
Old 08-30-2008, 08:51 AM   #14 (permalink)
inscracefan24488805's Avatar
inscracefan24488805 is on a distinguished road
Post Hey!
If you're looking for someone to test out this homescreen, let me know. I've got Facade and PhoneAlarm on my phone now. I'd be willing to test it out for you.
Cindy
inscracefan24488805 is offline
Old 08-30-2008, 09:02 AM   #15 (permalink)
dafoxs's Avatar
Looks great. do the panels slide up and down or does the forground stuff slide up and down? not sure if that makes sence.
dafoxs is online now
Old 08-30-2008, 10:31 AM   #16 (permalink)
BigTK's Avatar
I'm not sure there is a problem, Like I said I transferred to files to my Q and selected the home screen from settings and got a "the homescreen selected..." message. So I restarted and there it was.
BigTK is offline
Old 08-30-2008, 10:45 AM   #17 (permalink)
BigTK's Avatar
Looking good, man!
Thanks, I don't have a clue what I'm doing. I cannibalize code from here and there, make some edits and leave it at that. Standing on the shoulders of giants I think they say. However, minus a couple heavily edited graphics the PA skin is from scratch.
BigTK is offline
Old 08-30-2008, 10:50 AM   #18 (permalink)
BigTK's Avatar
Cindy
That,s cool. I'll just post the thing in a bit.
Well I'm WM5.0 so nothing "slides" it is done with a 4 page HS.
BigTK is offline
Old 08-30-2008, 10:57 AM   #19 (permalink)
dafoxs's Avatar
Ill be interested in the coding also.
Old 08-30-2008, 11:10 AM   #20 (permalink)
BigTK's Avatar
My zip file is 485kb and I can't upload it ??
BigTK is offline
