Old 08-13-2008, 06:25 PM   #1 (permalink)
new_guy234 is on a distinguished road
Default Bears Theme???
Is it possible for someone to make a HS with the following picture for the Chicago Bears? I'm currently using a WM7 theme that uses SmartToolkit and SmartMonitor. It works alright for the most part, but the signal meter isn't accurate and the temp meter doesn't work at all.
If possible, I'd like something that has a memory meter, sd card meter (if possible), battery meter, a signal meter, last used apps, voice/email/sms indicators, time & date, appointments, and a shortcut to the wireless manager somewhere.
I'm hoping there's a way to make it without Facade, because I don't have it.
I really appreciate it. Oh, and as a side note, I'm trying to read up on .xml so I can make some myself, but I don't think I'm anywhere close to what you guys/gals can do yet.
Last edited by new_guy234; 08-13-2008 at 06:45 PM. Reason: ...forgot to add the picture for the HS.
new_guy234 is offline
Old 08-13-2008, 11:33 PM   #2 (permalink)
inscracefan24488805's Avatar
inscracefan24488805 is on a distinguished road
Post I'm working on this one.
I'm working on this one for you. Trying to work out one bug in it. I hope that I'll have something for you sometime tomorrow evening.
Cindy
inscracefan24488805 is offline
Old 08-14-2008, 01:12 AM   #3 (permalink)
I look forward to seeing it and really appreciate you taking the time out to work on it. Thanks.
Old 08-14-2008, 07:48 PM   #4 (permalink)
Post Here's what I've worked up for you.
SmartMonitor required.
The Following User Says Thank You to inscracefan24488805 For This Useful Post:
new_guy234 (08-15-2008)
Old 08-15-2008, 01:52 AM   #5 (permalink)
Awesome!!! I really appreciate it!!! And the extra screen of a football field was a great touch, along with the helmet for the missed call screen!!!
Thanks a bunch!!!
Old 08-20-2008, 10:22 AM   #6 (permalink)
THEONLYMESSIAH's Avatar
THEONLYMESSIAH is on a distinguished road
Send a message via AIM to THEONLYMESSIAH Send a message via MSN to THEONLYMESSIAH Send a message via Yahoo to THEONLYMESSIAH
Default da bears
da bears my favorite team this is great
WHY SO SERIOUS?
THEONLYMESSIAH is offline
Old 08-20-2008, 10:37 AM   #7 (permalink)
Default question
after u unzip this where do u put the files so that they can show up in the settings homescreen?
WHY SO SERIOUS?
Old 08-20-2008, 10:58 AM   #8 (permalink)
search is your friend..
http://www.everythingq.com/forum/q-h...ons-10323.html
THEONLYMESSIAH (08-22-2008)
